I have a doubt with the temperature of the edge. When I touch it I feel it too hot. Here in Seville (Spain) we have about 38 ° to 40 ° and I think the temperature of the edge is about 50 °. Is this correct? Should I lower the temperature? Greetings and thanks.
As it’s quite hot outside, Edge can heat up to that temperature. There should be no issues with 50°C.
Lowering the temperature to 40 ° will not be a problem?
What do you mean by “lowering”?
Put imu temperature at 40 °. It will not affect negatively.
Sorry for my bad English. Thanks
