I am trying to process the logs from a field trip today and the base location gives me a good fix but when i process the rover logs i only get single and none of the correction work. Please help.
Hi @sgeyeuk,
Could you describe your workflow a bit? Do you pass through the steps described in this guide to process raw data logs from the rover?
Also, please share your processing data. I’ll try to process it as well.
Hi Thanks for the reply. I’m afraid this was user error. I forgot the input the base position with a - before the longitude.
