Heading seemingly not being transmitted by NMEA message
Hello,
I currently use an RS3 and Carlson Layout to lay points out.
I am using tilt compensation (but turning it off doesn’t change anything)
I’ve noticed since approx 32.2 that I am no longer getting my heading (or possibly, proper heading) in Layout. A bit hard to explain but basically, I’m no longer getting proper “directions” to my target point.
If I turn 360 in emlid flow my “forward arrow” turns with me. If I do the same in Layout, it stays fixed, never turning with me.
Anyone else use this combo have the same issue or insights?
Hi Matty,
Is it possible to record the NMEA messages sent by Reach to your third-party app, Carlson Layout? If so, could you please share them with me? I need the RMC or VTG messages.
Thanks!
And I need these messages from the time you encounter the issue. Thanks!
Hello, unsure how I can capture these messages. Via emlid logs?
I don’t know how it works with Carlson Layout. Some third-party software allows you to save NMEA messages as a file. If this is not possible, you can use a Lefebure app.
You can read more about the integration here.
