Hello,
In documentation i found “Use HDMI cable with Micro-HDMI connector to connect camera to the HDMI-IN port on Edge”
But where i can buy this cable ?
Regards,
Thierry
Hello,
Regards,
Thierry
Hello,
Here, custom made, https://aerialpixels.com, quite expensive.
Or https://www.globe-flight.de
Adafruit for DoItYourself solution: https://www.adafruit.com/?q=DIY%20HDMI%20Cable%20Parts
Marc
But it depends on what connector you need on the other end of the cable!
Thanks !
I’d go this route. Means you can get the connector type and orientation perfect for your setup, as well as more increments in length available with ribbon cable. I bought mine from AliExpress and lay it flat underneath some other electronics to get it to the camera. Works a treat.
