Hi
I’m currently trying to use the HC-12 radio for the communication between the base and rover but I’m not having any luck with it.
I chose the base to send the corrections through UART with baud rate of 9600 and rover receiving corrections with the same settings. It works straight away if I do it with Wifi according to the reach docs. The connections and radios doesn’t seem to be faulty since when I connect them the same way to two different arduinos they can send and receive properly.
Thankful for any kind of help, thanks.
