As some of you may have seen, I have built my own custom quad for use in the Agriculture field. I have it setup to stream video via wifi and 4g using Gstreamer (per the docs).
I have a company that has provided me with 4g router that I use standalone for my PC the service provider is very good in my area with 20+ Mbs up or down service. However, when I run gstreamer across wifi to the same router that I run my PC with, there is no issue whatsoever but when I run the stream via 4g it causes terrible Pixelation/ Slow frame refresh issues and no matter how low I create the resolution the outcome is always the same.
Different from some on here I use a cloud based VPN service that issues my devices with IP addresses without having to purchase static IP ($500.00) because the carrier doesn’t make the IP’s public.
Has anyone run into this issue? Maybe you could steer me into the correct direction because as of right now the company that builds the router has their own PI’s on hand and are bench testing my setup and are arriving at the same roadblock as I am using the Doc’s provided on the site.
Thanks guys
