GST empty fields - Reach M2
Is it possible that you can have zero’s instead of empty fields in the nmea $xxGST sentence?
Rgds
Henrik
Hi @g5q9785j5c,
Could you tell me more about this? The GST message is the position error statistics, so having all the values as zero is impossible.
Why do you need zero instead of empty fields?
Hi
I does’nt have to be zero’es in fact it only has to be “something” instead of empty fields. The software needing the xxGST is giving an error due to empty fields. The only field needed by the software is the last field with vertical error.
@henrik.skovmose,
When you were testing it, was the receiver provided with a sky view? Does it have at least a Single solution?
The string is empty because the M2 doesn’t have a Solution, so it couldn’t compute its position or the estimated accuracy.
Yes of course!
it’s only some of the fields that are empty…
$GPGST,112917.00,4.600,0.240,0.170,0.430*71
|3|Error ellipse semi-major axis 1-sigma error, in meters|
|4|Error ellipse semi-minor axis 1-sigma error, in meters|
|5|Error ellipse orientation, degrees from true north|
emlid-gst
i have attached a picture since i cant send an example in this field
I see. Thanks for the screenshot. I’ll confirm with the developers why fields 3,4, and 5 are empty. Thanks!
@henrik.skovmose,
I’ve heard back from the developers. They confirmed that we should have data for fields 3, 4, and 5, but it’s currently not being reported in the GSA sentence.
At the moment, this isn’t on our roadmap, so I don’t have a timeline for when a fix might be released. I’ll let you know as soon as I have any updates on this. Thank you!
Thank you,
looking forward to when it gets fixed.
Until then we will have to buy a GPS that can fulfill the nmea standard…
