I would like some help about the obs files. I view them using Rtkplot. Are they ok? Or that “gaps” in the satellite view means that something can be improved?
I use a 10x10 aluminium ground plane inside the plane and made a hole for the antenna.
That gaps are cycle slips. They show that the signal from a satellite was disturbed. It’s possible to reduce their quantity and improve the quality of the signal.
Let’s start with the antenna raising. In the meantime, the airframe of your plane seems to constrain the antenna satellite visibility. You should place the ground plane with an antenna above the airframe.
I did some tests on my house’s roof. The left log is with the ground plane inside the airplane and the right log with the ground plane outside the airplane.
Both of them looks similar and the signal is good.
Maybe that cycle slips appear when the plane is moving? In the second log of my previous post (the one with more cycle slips) I remember the wind was 7m/s and in the first one (less cycle slips) 2m/s.
