Gross record of the survey, how to download?
I am a topographer and need to download raw records for post-processing.
I did not find a way to unload the raw records
It is best to tell us what you tried to do, what happened when you tried, and what you expected to happen. That way we are able to understand your problem better.
In ReachView; Logging tab; see all your log files; click the blue download icon beside the log you want to download. It is very easy!
this did not work,
because the right thing would be to click on the logging and it to download.
but he keeps charging for hours and never closes the file, I have to fehar him alone.
and it gets too big, I know it should not be because it’s just a point.
so I do not think the raw logs of a survey are unloaded by logging.
I tried in several ways …
in the post-processing emlid site documentary talks about raw logs and logs that are two different things.
accurate record of gross records.
Could you please post some screenshots of the moment when things go wrong?
THE ISSUE THAT IS LOADING FOR HOURS AND NEVER DATES THE FILE.
I NEED THE FORMAT IN RINEX PRA POS-PROCESSING IN THE TOPCON TOOLS.
AND HE DOES NOT HAVE THE OPTION TO SELECT WHOSE LIFTING SHOULD DOWNLOAD LOWER A SINGLE FILE
I NEED TO DOWNLOAD THE FILES FROM ALL POINTS.
olá Igor, também sou do brasil, você ja conseguiu descarregar os “dados brutos” ? estou com este problema toda vez que vou na guia loggins e clico RINEX ele passa horas e não fecha. meu arquivo só contem 2 pontos de 5minutos cada e ele nunca baixa o arquivo.
somente quando clico pra encerrar dai ele faz um unico arquivo e não acho que tem que ser assim.
Hello Igor, I’m from Brazil, have you been able to download the “raw data”? I’m having this problem every time I go on the loggins tab and click RINEX it spends hours and does not close. my file only contains 2 points of 5 minutes each and it never downloads the file.
only when I click to close it does it make a single file and I do not think it has to be this way.
how you download the “data gross”?
i’am dnot success for dowmload, the emlid reach up time for download is self at guide “loggins” …
my static survey where I collected 2 3-minute points.
when I click the rinex button to generate the file.
he counts and counts the minutes and never closes closing the file.
how can this be if the points is not so great.
he should count and stop by closing the file himself.
it does the opposite, stays for hours and never closes.
there should be a form in the app that we could select the survey done and export it, I say this to the raw data I know in RTK it exports.
I was unable to export by rtklib as well.
I just need to export the raw data in rinex to post-process in other software.
Hi @topoagrime,
Once you are done logging click this switch and the logging will stop and the file will be available for download.
Ok, desde já agradeço sua ajuda, aprecio sua atenção,
O notei o seguinte, consegui baixar interrompendo o envio dos dados brutos
"log" porém notei que o quando Clico na guia “Loggins” e no botão “rinex
3.0” ou qualquer outro formato. Ele está na realidade rastreando um ponto,
por isso que nunca terminava de carregar os dados, sempre contando o tempo
, quando fechei um arquivo e importei para o software de processamento vi
que ele baixou os dados brutos exatamente no horário que iniciei e
finalizei o “log”.
Ou seja se eu iniciei meu download as 6:30:00 e finalizei as 6:33:00 ele me
dá os “log” deste horario, e nao dos levantamento que fiz anteriormente
semana passada.
Ou não está funcionando correto, ou ele não descarrega dados brutos de
levantamento estático.
Porque em outros receptores gnss de outras marcas funciona da seguinte
forma .
Após ter finalizado o levantamento tanto estático tanto cinemático os dados
brutos ficam disponíveis na memória interna do receptor .
São gerados arquivos, que quando conectamos o cabo serial no receptor e no
computador ele funciona como unidade de disco, tipo um pendrive, podendo
acessar os arquivos de todos os levantamento de inúmeras datas, podendo
seleccionar qual levantamento queremos exportar .
Outros já tem um app que quando instalado o receptor no computador,
abre-se o app e lá conseguimos copiar os dados do levantamento .
Pelo que notei ele não exporta os dados brutos de levantamento feito e sim
rastreia quando clicamos no botão rinex.
Existe alguma maneira de fazer este tipo de exportação ou meu emlid reach
está com problema ?
You need to enable logging before doing the survey, not after.
ok, i’ll try.
very good, thank you very much is exactly what i am needing, now i understand what happened.
i have another question. should i also connect log’s when lifting on rtk? to do the post-processing when working in an unknown coordinate?
If you want to do post-processing then keep the logs turned on. Survey project does not collect raw data, only points. So you need to keep logs enabled.
THIS IS THE FORMAT I NEED.
THIS IS THE FORMAT I HAVE.
raw_201801301631_RINEX-2_12.zip (223.3 KB)
tem como me fazer um favor ?
ver o que ha de errado meus software não consegue importar.
Re solved, I converted rinex as GNSS SOLUTIONS rinex converter.
but I did not want to use Emlid. I unfortunately got configured to use RTK, I bought two radios, the first one was wrong, so I was told that it was the dragonlink v2 433, finally with the intuition to make sure I bought the 3DR 915mhz. Unfortunately I did not succeed.
I’ve been trying for 3 weeks, and I can not solve it …
so I play the towel.
