Hi there,
Im using Kinematic processing with Emlid Studio 1.9. Is there a way to get the output POS file in UTC time as opposed to GPS time?
cheers,
Javier
Hi there,
cheers,
Javier
Javier,
If you open up the Kinematic Processing Settings (the Blue Cog on the left panel), then scroll down to “Time Format”, change it to “hh:mm:ss UTC”. The .POS file will then have the solutions in UTC, even though the bottom of the Map shows GPST (which I think Emlid should change if that is what the solution is in).
Joel
Hi @jleon,
I agree with @joelbladen. If you change the time format in the post-processing settings to UTC, the result .pos file will contain the proper times in UTC.
@joelbladen, I’ve noted your feedback about the GPST label. Thanks for bringing it up!
Thanks. Yes that works perfectly
