We tested GPS + Beidou in RTK settings and it worked better in RTK mode. However, if we used the raw files recorded with GPS + Beidou either for static surveying or PPK processing, the files seems to not work. Does anyone experience this issue?
EZSurv reads native UBX files (so I did not convert the files to RINEX)
As shown and highlighted on the image, both constellation were used in the PP solution (GPS and BeiDou)
EZSurv can post-process all constellations (GPS, Glonass, Galileo and Beidou).
With EZSurv Edit / Process Parameters, you can activate / deactivate a constellation. We recommend you keep all constellation checked.
Your demo license has expired, so that is the reason you cannot import your files.
