i the past i was testing reach with correction service over internet.
now i have setup my reach successfully with my rfd900 (868) like here:
Today I noticed that all gps bars simultaneously moved around 10 dbm up and down like on picture.
The cause I found on my new 4dbi antenna which was mounted 20 cm from the gps antenna.
After I had removed the radio antenna 1 meter from the gps antenna was everything again in order.
my rfd is running with 27 dbm and 30 % duty cycle…
