Positive is up and negative is down. The antenna is up from the camera senseor so yes it is a positive number. You say the antenna is centered horizontally, but is that at a resting state? If so then how are you calculating for the tilt of the aircraft and where that then puts the relationship. It will affect the y-axis as well if you wanted to scrutinize. Think about this…
Are you using GCP’s?
