At the end of this post is a definition of the NMEA $GPGGA string. My question is : What does emlid put in field 13?
It does not appear to be age of differential. as it has both positive and negative values.
Emlid GGA string .
$GPGGA,212314.00,4253.0110320,S,14724.5401773,E,1,13,1.0,26.961,M,-4.118,M,0.0,*76
NMEA GGA definition
1 = UTC of Position
2 = Latitude
3 = N or S
4 = Longitude
5 = E or W
6 = GPS quality indicator (0=invalid; 1=GPS fgeoSepix; 2=Diff. GPS fix)
7 = Number of satellites in use [not those in view]
8 = Horizontal dilution of position
9 = Antenna altitude above/below mean sea level (geoid)
10 = Meters (Antenna height unit)
11 = Geoidal separation (Diff. between WGS-84 earth ellipsoid and
mean sea level. -=geoid is below WGS-84 ellipsoid)
12 = Meters (Units of geoidal separation)
13 = Age in seconds since last update from diff. reference station
14 = Diff. reference station ID#
15 = Checksum.
