Anyone have any luck getting this work?
Connecting to Reach RS ROVER via Bluetooth COM3 (incoming) (there is a COM4 outgoing also but not sure if that is the correct port to use).
I am not connecting via COM1 with a cable (no old school serial port on PC, but I know I can get a Serial to USB cable).
There is a COM6 when using a USB to PC connection, but that doesn’t seem to do anything either.
Have already reflashed both units which solved the Edison driver problem I had initially.
I do not see any indication of my location or tracks in Google Earth Pro… it does say “Reading COM3 though” and I see my Realtime GPS under Temporary Places “polling”.
More info:
https://www.gpsbabel.org/htmldoc-development/fmt_nmea.html
