https://community.emlid.com/uploads/default/original/2X/3/369e1a1ba8486b210d58330b95ad394cb73821f8.png
https://community.emlid.com/uploads/default/original/2X/3/316f3de652b88335293965ceeda9929e99825b4a.png
https://community.emlid.com/uploads/default/original/2X/7/7dc346c549d325c42af08413d06f21648bee38a5.png
https://community.emlid.com/uploads/default/original/2X/1/181e41e6f953d5177b7942e77f06b9b1dcb085d3.jpg
Hope i have good signal strength on both base and rover but still my rover reminds float even after 20min…
reply…
bide9d
I’m seeing:
6 “R” satellites. (1 is bad strength)
That should allow glonass ambiguity resolution (AR) if it is enabled.
3 “G” satellites. (maybe more off-screen)
If you have 2 more off-screen and they are over the minimum SNR (default 35), then that should allow GPS AR.
1 “J” satellite. I’m not sure if it can be counted with GPS for AR or not. Maybe it will only be used for error-correction.
I think I’m safe to say that where you read “AR,” you can think “fix.”
Reply
sivashankar7d
Can you give me some more clear idea on this. So you are saying me to consider this as fix.
And one more, when use gps_glonass_5hz i’m at least getting float mode, but when i use gps_5hz its even more worst, i can see both green and Gray bars above the threshold level but the system still reminds in single. This is crazy, can any please give some idea in point why should i use only gps_glonass and not others…
