GNSS vs. RTK: Understanding the Difference and Choosing the Right Technology for Precision Mapping
In the world of geospatial data collection, choosing the right technology can make all the difference in the accuracy, efficiency, and success of a project. Two popular technologies in this field are GNSS (Global Navigation Satellite System) and RTK (Real-Time Kinematic). While they both enable precise positioning, they differ significantly in their methods, applications, and accuracy levels. In this article, we’ll explore the key differences, advantages, and considerations of GNSS and RTK to help you determine which technology is best suited for your needs (Figure 1).
Figure 1: GNSS can achieve an accuracy level of 2-10 meters, while RTK can enhance the GNSS accuracy to centimeter level (Image source: Emlid.com).
Understanding GNSS: Broad Coverage with Reliable Positioning
The GNSS, or Global Navigation Satellite System, refers to a network of satellites that provide global positioning information. The most well-known GNSS systems include the U.S. GPS, Russia’s GLONASS, the European Union’s Galileo, and China’s BeiDou. These systems use a constellation of satellites orbiting Earth to transmit signals that can be used to determine the precise position of a receiver on the ground.
Key Characteristics of GNSS
  1. Wide Coverage Area: One of the most significant advantages of GNSS is its global reach. GNSS receivers can access satellite signals anywhere on Earth, making it ideal for global applications.
  2. Standard Accuracy: GNSS alone can typically achieve an accuracy level of 2-10 meters, depending on the receiver’s quality and the environmental conditions. For many applications, this level of accuracy is sufficient.
  3. Autonomy: Since GNSS receivers communicate directly with satellites, they do not rely on a nearby base station or real-time corrections. This independence makes GNSS particularly valuable for applications in remote areas.
Applications of GNSS
GNSS is widely used in applications where centimeter-level accuracy is not essential, or where a network for real-time corrections is not available. Some popular applications include:
  • Fleet tracking and management
  • Basic navigation (e.g., personal GPS devices)
  • Asset tracking in large, dispersed areas
  • Marine and aviation navigation
GNSS provides reliable and accessible positioning for these purposes but may fall short when precise accuracy is required.
RTK: Real-Time Corrections for High Precision
RTK, or Real-Time Kinematic, is a technology that builds on GNSS by using differential corrections to achieve centimeter-level accuracy in real-time. RTK utilizes the same satellite signals as GNSS but enhances them through the use of a base station that communicates with the receiver, or rover. The base station is a known fixed location that calculates corrections based on any deviations from its known position and sends these corrections to the rover in real time (figure 2).
Figure 2: Showing the GNSS, Base and Rover connections to reach the RTK’s centimeter-level accuracy.
Key Characteristics of RTK
  1. High Accuracy: RTK is capable of delivering centimeter-level accuracy (within 1-2 cm), making it ideal for applications that demand precise measurements.
  2. Real-Time Corrections: RTK requires a real-time data link between the base station and the rover, which can be achieved through radio, cellular, or internet connections. This enables corrections to be applied instantly, allowing for real-time precision positioning.
  3. Limited Coverage Range: Since RTK relies on a base station, the rover must be within a certain distance (typically 10-20 km) to maintain accurate corrections. The accuracy diminishes with distance, as the corrections become less effective over greater ranges.
Applications of RTK
RTK is widely used in industries where high accuracy is paramount. Some common applications include:
  • Surveying and land parcel mapping: RTK’s centimeter-level accuracy is invaluable for boundary measurements and land division.
  • Construction and site layout: Precise measurements are essential in construction, where errors can be costly.
  • Precision agriculture: RTK allows for the accurate placement of seeds, fertilizers, and pesticides, reducing waste and improving crop yields.
  • Autonomous vehicle navigation: For self-driving vehicles, RTK provides the level of accuracy needed to follow precise routes in real time.
GNSS vs. RTK: A Head-to-Head Comparison
When deciding between GNSS and RTK, it’s essential to understand the strengths and limitations of each.
Feature GNSS RTK
Accuracy 2-10 meters 1-2 centimeters
Coverage Global Limited to base station range (10-20 km)
Real-Time Capability Limited (GNSS provides location data only) Real-time corrections enable instant positioning
Cost Generally lower (standard GNSS receivers) Higher (requires base station and data link)
Reliability in Remote Areas High autonomy, no need for base station Requires proximity to a base station
When deciding whether GNSS or RTK is the better fit, consider the accuracy requirements, project budget, and field conditions.
When to Use GNSS
GNSS is an excellent choice for applications where:
  • Moderate accuracy is sufficient (2-10 meters).
  • Budget constraints make RTK an impractical option.
  • The project is in a remote area with limited communication infrastructure, making a base station impractical.
  • Global coverage is necessary, such as for fleet tracking or asset management over large areas.
When to Use RTK
RTK is ideal when:
  • Accuracy is critical, and centimeter-level precision is required.
  • Real-time corrections are necessary to maintain precise positioning.
  • The project area is within a reasonable range of a base station, or there is access to a network of RTK base stations.
  • The application demands accuracy to reduce errors, such as in surveying, construction, or precision agriculture.
Hybrid Solutions: The Best of Both Worlds
In some cases, a hybrid approach may be the best solution. Many modern GNSS receivers support RTK and are compatible with correction services, allowing users to switch between standard GNSS and RTK modes as needed. For instance, a surveyor may start a project using GNSS for general mapping, then switch to RTK mode for high-accuracy measurements in specific areas.
Additionally, advancements in GNSS augmentation systems, such as SBAS (Satellite-Based Augmentation Systems) or PPP (Precise Point Positioning), are narrowing the gap between GNSS and RTK in terms of accuracy. While RTK remains the gold standard for real-time precision, these alternatives can enhance GNSS accuracy and may be suitable for specific applications.
Final Thoughts
Both GNSS and RTK play crucial roles in modern geospatial technology. While GNSS offers accessibility and global coverage, RTK delivers the precision required for detailed measurements. By understanding the differences between these two technologies, professionals can choose the best tool for their specific needs, ensuring accuracy, efficiency, and project success. Whether navigating remote terrains with GNSS or achieving centimeter-level accuracy with RTK, selecting the right technology can make all the difference in achieving accurate, dependable data in the geospatial field.
I think you might mean SPP (single Point Positioning). GNSS is the system, not a method of use. SPP uses signals from Global Navigation Satellite Systems (GNSS), like GPS, to calculate the position of a receiver based on pseudorange measurements from multiple satellites. RTK is a technique that enhances GNSS positioning accuracy by using carrier phase measurements along with corrections from a nearby base station or network of stations.
Feature Single Point Positioning (SPP) Real-Time Kinematic (RTK)
Accuracy 5–10 meters Centimeter-level (1–4 cm)
Data Source Satellite signals only Satellite + correction signals
Infrastructure None Requires base station/network
Cost Low Higher (due to hardware/subscription fees)
Complexity Simple More complex setup
Latency Near-instantaneous Requires real-time processing
Use Cases General navigation, consumer Precision-demanding industries
Hi Michael,
Thank you for your thoughtful and detailed comment. I appreciate your expertise and the opportunity to clarify some points.
You’re absolutely right that GNSS refers to the overarching system, while SPP (Single Point Positioning) and RTK are specific methods or techniques of utilizing GNSS signals. My article aimed to focus on the practical applications of GNSS and RTK in different contexts rather than delve into the technical classifications.
Many thanks for the comment!
I understand you are trying to keep it a higher level but I wouldn’t refer to GNSS as a method. System is literally in the name. We have enough misunderstandings and interpretations of verbiage in the Surveying industry that something as overarching as this needs to be accurate when used at a high level which could be consumed by persons that may not have any experience. It starts them off on a bad footing.
As Michael pointed out, I do think that even though your intentions are good, that you are introducing inaccuracy and confusion into your article that do not belong.
GNSS is the over arching system. SPP and RTK are workflows operating within that system. Please do not try to make the material easier to understand by presenting it in a way that is technically incorrect.
Good grief. Off topic… I know, but what is the best AI currently to use to write papers?
Just for the hell of it… copy paste this into ChatGPT and let me know what ya get? :thinking: :smirk:
Can spot this :poop: a mile away.
Or if feeling lazy… click here:
AI isn’t perfect… it’s just like people trying to understand learning things, subjects or data…
First thing that stuck in my mind from college days learning the Fortran language using punch cards as input,
Garbage in, garbage out
Totally agree with @michaelL & @dpitman. The use of the term GNSS rather than SPP, Autonomous GNSS, or Uncorrected GNSS as a way of distinguishing it from RTK (a form of Differentially Corrected GNSS) is inapt and introduces noise to the discussion rather than clarity.
The basic premise of the piece is valid, but the misuse of terminology will only serve to misinform and confuse those who it aims to educate. It would have been very easy to just use the correct terms…
“GNSS Positioning”. Positioning utilizing Global Navigation Satellite SYSTEMs. Here’s why it should always be kept separate…
Autonomous = Uncorrected
SPP, eSPP, POD, Carrier Phase and Shadow Matching are types of Autonomous positioning UTILIZING GNSS.
Augmented
DGNSS, SBAS and GBAS are types of Augmented positioning.
High-Precision = Corrected
RTK, NRTK and PPK are types of High-Precision positioning UTILIZING Global Navigation Satellite SYSTEMs. Precise Point (PPP) is also High-Precision but is a completely different method and many would consider it another type.
So now you can see how complicated it can get and why we need to be precise and consistent with our language.
