Hy guys
I would like to create my own base station on the roof using this antenna
is it ok ?
Can you suggest the adaptor to connect with my reach ?
thx
Francesco
Hy guys
is it ok ?
thx
Francesco
We are using Tallysman antennas on our roof, I have no idea about performancce of Garmin antennas, but they are not meant for precision applications.
How long will be the cable running to your roof?
Look into:
https://www.digikey.com/product-detail/en/tallysman-wireless-inc/33-3710-01-01/1526-1019-ND/4862791
Yes
I know your antenna but the cost of your seggested antenn is double of Grarmin… sorry but the price it’s impotant for me …
Thx
Francesco
In that case you can make your own mount and ground plane for TW4721 that came with Reach. I doubt that you will be able to get good performance with Garmin antenna.
OK
in case I want to but the tallysman I have to buy some cable adapter or is ready to use with my reach ?
THX
Reach has MCX connector, tallysman antennas usually come with TNC (but check the part number). You will need a MCX to TNC cable with proper length. We offer a cable like this, but only 2 meters:
https://emlid.com/shop/mcx-male-tnc-male-2000mm-cable/
Hy
one more questrion
I have 24 h of static observation how can calculate the average lat long of my base station with rtklib ?
thx
Francesco
Static or Singel base? do you have other data to process with base?
If not you just enable statistics in RTKplot and use base raw/rinex as solution. Stats displays AVG, STD and RMS from origin
I acquired the data in static mode contiunuos and I have rinex observation from refernce station away +o- 8 km from me but the rinex are 1 file for each our so I don’t know if rtklib can process 20 separeted file and ouput the average valur
thx
Francesco
Sure thing. Use base files and place them in the rover colum in RTKpost and refrencefile in base colum.
Place all rinex refrence files in one folder and point RTKpost path to this folder and ad wildcard (*) in front of the filetype.
For example your refrence files is named “refrencefile.ubx” , then you will use " *.ubx" instead. This will make RTKpost read all files of .UBX type or any other type you choose.
HY
I know but the problem is that at the end I would like to receive from postprocessing a unique value that represent the oordinates of my antenna instead a receive a log with one coordinate for every sec of observations
Thx
Francesco
Are these seperate point within the same log or seperate points from different logs?
One log with separate point … I know that I can use excel to calculate average but I suppose RTKLIB has more powerful alghoritm i hope
attached the result base_20170925.zip (282.2 KB)
I am pretty sure this is what you are looking for… ?
Edit: Its not your file, its from a different location
Francesco,
Use the ? wildcard in RTKproc
For each character that is different in the filenames just insert a ? then RTKlib will read them all
example
DataFromReference_20171006_0000.rtcm
DataFromReference_20171006_0200.rtcm
DataFromReference_20171006_0300.rtcm
Will all be read together by:
DataFromReference_20171006_0?00.rtcm
or
DataFromReference_20171006_???.rtcm
Once processed you will have one big file full of all valid fixes.
