Hello everyone. Im new to GSNN and Emlid. Just got the RS4 PRO. I have it so that Its just the receiver connect to satellite, not with the base.
Is there a good step by step video or a very easy way to just follow how to step this up and practice with it. I was following a video by “3d mapping tools” on YouTube but he has it with the base.
im new and just looking for a step by step guide. thanks
To help you get started with your receiver, I’d first like to share our guide on how to connect to it. You can find it here.
Now, to achieve centimeter-level accuracy, receiving signals from satellites alone isn’t enough—you also need correction data.
When you have a second receiver, you can configure one as a base station and the other as a rover. In this setup, the base station provides corrections to the rover.
If you don’t have your own base station, you can instead use an NTRIP correction service. There are many providers around the world that deliver correction data over the internet—such as Point One Navigation in the USA.
When using an NTRIP service, there are two main requirements:
The correction data must be provided in RTCM3 format.
For the best RTK performance, the correction source should generally be within about 60 km of your rover.
Once you’ve found a correction service, you can follow this guide on how to configure your receiver to receive RTK corrections from an NTRIP service.
If you need any further assistance, please feel free to contact me directly at [email protected]. I’d be happy to help you get everything set up.
