Hello Emlid Team !
Is there a way to get the coordinates I see on rtkplot in an .txt file where I can see latitude longitude and height vs time ?
I try to check on each log file but didn’t find those data.
Thanks !
Hello Emlid Team !
Thanks !
You are looking for the Positioning Solution file. You must create it by post-processing your raw log files with RTKPOST.exe, or just enable it in ReachView while in Rover mode:
The format of the file is described in the RTKLIB docs on page 103 of this PDF file:
DESCRIPTION
A positioning solution file is just a text file as output of RTKNAVI or RTKPOST. he file is separated to records or lines by CR/LF. Each records consists of fields. The following table shows the format of the positioning solution file.
It contains these fields:
Thanks for the hint. Was super-useful !
