Geotagging error
Hello Community,
I am having some issues with geotagging. I already read a diff post but couldn;t fix my issue. I also get the message: must contain 0 photos
I am using a LiDAR unit and it also takes pictures. I am trying to tag those photos.
My base is a rs3 that was logging. I take the rinex (24.0) and the nav (24P) frome the base. i can export a rinex file from the lidar unit. I think that file is the issue. What is wrong with the file? No Time Marks? I can export or convert all kind of files, just cant figure out the correct one.
I can also export a .pos file from the lidar software and then the tagging in emlid studio works but the accuracy stays the same. Any ideas?
I included the files in a wetransfer link:
Please let me know what i can do.
Thankyou in advance.
Jack
Hi Jack,
Welcome to the community!
I checked the files that you sent. The observation data from the LiDar unit has a different time-mark format.
I changed the format of the two-time marks and tried to reprocess the data in Emlid Studio:
After that, Emlid Studio asks for two images. It seems that the time mark format is the cause.
As you mentioned, you use a LiDAR unit. Can you modify this part when exporting the file?
Thankyou, That helped!
Hello,
i changed the file but now emlid studio is asking for 227 photo’s but only have 226. Where is that one photo coming from? Did i delete something i shouldn’t?
Thankyou in Advance,
Jack
A post was split to a new topic: Issue with geotagging
