Hi Emlid team, do I understand correctly that with the new reach image 2.x versions, the M8T 3.01 firmware is used?
Hi!
Actually, it’s not. After internal tests we discovered that RTKLIB requires some fixing before we can use this new firmware properly.
Here a nice litte screenshot using the SPG firmware from u-blox with Reach and Galileo:
We are all waiting for a public release of the Galileo support. A public base station is used for correction signals.
How to enable Galileo UBX messages (if you flashed the new firmware at your own risk):
Edit file /usr/lib/python2.7/site-packages/reachview/app/templates/index.html
- Search for “galileo_select”
- Remove the starting comment
before and the ending comment-->
behind in this area - Reboot device
- Enable Galileo in the configuration
- (Reboot device)
- Galileo should be enabled, also in the configuration file
/etc/reachview/current_config.json
the settingrtk settings -> positioning systems -> galileo
should change from false to true - When you update Reach, the changes must be made again
Thank you emlid, that the preparation is already done, now we are just waiting for the official release
How to enable RTCM3 1097 messages for Galileo:
- find “1127_select” and add the following text after the closing table cell
</tr>
<tr> <td>1097</td> <td>GALILEO MSM</td> <td class="rtcm-time-inte - Pastebin.com - reboot reach
- Enable message in reachView
- You can check the configuration in
: The configurations inrtcm3 messages
should now contain an entry with1097
- You can also check the running processes using the command
top
in the console: you should find a running process with the following parameters:/usr/bin/RTKLIB/app/str2str/gcc/str2str -msg 1087(1.0),1097(1.0),1077(1.0),1006(10.0)
You can also add the Multiple Signal Messages 1077 (GPS) and 1087 (GLONASS). These messages can be used instead of 1002 (GPS) or 1010 (GLONASS). The Multiple Signal Messages contain more information than the simple signals, e.g. Doppler measurements:
You should keep an original copy of the edited index.html!
Have fun!
Now that there appears to be a working version of RTKLIB with Galileo and UBlox M8T, will there be an upgrade coming anytime soon? I seem to be able to satisfy my needs for now with the beta 2.2.4, but initial tests seem to show lower time to first FIX and more consistent FIX with GPS+GLO+GAL+SBAS. But, I’ll take any improvement Emlid can add.
It is not clear to me it the M8T needs new firmware and Edison reflash to upgrade at that point.
Appreciate the good work…
Hello,
I have an ublox neo 6 that i connect to an android tablet. I wish to knwo please what is the right configuration for stand alone positioning
