I connected Navio2 to u-center to visualize Galileo sats, but I can’t. I was wondering if an updated is need it or how to solve this issue.
Thanks in advance.
source: (Emlid website)
GNSS receiver
Tracks GPS, GLONASS, Beidou, Galileo and SBAS satellites. External antenna with MCX connector
Mark has described the procedure of connecting u-center correctly. Although, Navio2 does not support the signal reception of Galileo constellation. That is why your configuration has been reverting back.
When trying settings on my Navio2 GPS, enabling Galileo and disabling Glonass, the “Send” command was doing nothing (like on your unit).
I had to reset the GPS default settings to have the “Send” command working. Before doing the reset take note of the GPS settings in order to restore them manually if needed.
