Does anyone happen to have the full weight of the navio+ as well the accessories like the GPS unit, power module, etc.
Navio+ board with metal stand-offs (could reduce a bit with plastic stand-offs) = 33g:
Navio+ GPS antenna = 31g:
USB WiFi dongle with high-gain antenna = 21g:
Raspberry Pi 2 with full/3 heat sinks = 49g:
Raspberry Pi camera = 3g:
I don’t have the Emlid power module but it is probably similar to the Pixhawk module at ~g:
But personally I would recommend a full PDB and BEC combo as that saves a lot of other weight.
This one is good when you need an APM PDB with both 12v and 5v BECs at 12g:
But this one is better (smaller and lighter) if a 12v BEC and not so high an output is not required (many FPV cameras and LEDs take direct 3S-4S battery input now) = 6g:
Thanks!
Emlid power module 26g:
Navio 2 + fixings 32g:
Navio 2 motherboard only 24g:
GPS antenna (as supplied with Navio 2) 31g (appears same as Navio+):
Thanks!
