I bought FLYSKY transmitter with FS-A8S receiver. After connection to pins and binding process I am trying to run RCinput.py but it shows zeros. Could you please tell what i did wrong. Please see photos below.
Hi Andrey,
Ardupilot is disabled, right? I see the LED, but just to confirm.
If so, please post output of sudo cat /sys/kernel/rcio/status/alive
Have you tried to connect Navio2 to the Ground control station? Is it recognized there? Is it possible to pass the calibration process?
no, it not works through ground control too
Hi Andrey,
How do you connect Navio2 to the Ground Control Station application? Are you using Mission Planner?
