Hello, I am working with RS2, when I do post processed it does not fix the point, getting frequency L1 / E1, converted to Rinex 2.10, use LeicaGeoOffice to process. I used the Surpad app to save the points and the satellite view doesn’t look like L2 either.
any suggestion?
Only the L2C signal is supported in the GPS system. Perhaps the app you are using is only tuned to read the conventional encrypted L2 signal.
I wish I had the option to see all the signals being read per SV in reachview…
