Hi all,
I was about to use FRAM to store sensor data + motor controls and use simple last updated sequence number for each value to make sure sensor data is updated, to avoid main cycle of program to stuck in reading sensor data. So I was expecting Navio python example for FRAM will work like a charm, due to all other Navio examples worked absolutely perfect. Unfortunately it did not:
Fram memory Write/Read test!
We will read value from the address 0x005 of the fram memory, then rewrite this cell and read it again.
Value in 0x005 is: 0
The cell was rewritten. The new value is: 0
Traceback (most recent call last):
File “./FRAM.py”, line 19, in
fram.writeBytes(0x103, [2, 12, 15, 3, 7, 2, 12, 12, 3, 4, 5, 6, 1, 12, 43, 123, 11, 23, 33, 11, 43, 12, 43, 35, 11, 111, 234, 124, 43, 12, 11, 122]) #Writing some value to the address 0x103 - 0x123
File “/home/pi/Navio/Python/FRAM/MB85RC04.py”, line 67, in writeBytes
self.bus.write_i2c_block_data(self.address, registerAddress, data)
IOError: [Errno 5] Input/output erro
Any help will be appreciated!
