When did you change the roadmap?
A roadmap is not a promise.
I dont see any firm commitments here, other than Emlid early on knew tilt compensation was a winner, and was investigating.
Sadly the IMU in the existing units weren’t good enough.
If you advertise a built in IMU and say it’s on the roadmap then you have made a future promise.
As of now the IMU isn’t used in any way, I can’t even get the data through nmea which is possible.
Do you think it’s okay to advertise a function and then not make it work for the consumer in any capacity?
You “might” be right, but you’re not.
