Hola! Necesito saber el flujo de trabajo para RTK con RS2 para una base con coordenadas desconocidas y rober trabajando en modo cinemático!
Desde ya, muchas gracias!
You can, average in a point shoot via RTK and adjust everything afterwards, PPK a base point against a local CORS or PPP with a service like OPUS. Averaging and transforming is the fastest in the field, but can be a pain in the office. PPK could be done in the field in depending on how quickly you can get the CORS corrections. PPP would require a separate trip.
Muchas gracias por su respuesta. Se a rasgos generales lo que habría que hacer. Lo que yo estaría necesitando es un paso a paso de dichos procedimientos. Muchas gracias!
As described above there are actually 3-4 different methods so you’ll need to do some research and maybe someone will jump on and detail them. I’ll do it if I have time between power outages.
AQUI ENCUENTRAS TODO:
