Hello everyone,
The flight mode channel is set to channel 8 by default on Mission planner. I want to change it to channel 5. The mission planner docs mentions it can be changed using the FLTMODE_CH parameter but it is not found in the full parameter list.
Does anyone have an idea what to do ?
Thanks
Note: I am using Fs-i6 x transmitter with its receiver so only 6 channels are available , and using the latest emlid raspbian image.
If someone faced similar problem in the future, I used mission planner on android and found the parameter in the full parameter list.
Don’t know why it was not found on the windows version.
Hi Moe,
Thanks for getting back to share the solution that worked for you!
