A question about the pole height on the drone. As you can see on mine, it’s pretty high. I noticed it not recommended to input an antenna height for Emlid studio. Is that because of the lever arm?
Hi Shaun,
Sorry, misunderstood your question. I’d suggest placing the antenna at 15-20 cm above the drone.
Yes. You’ll get the positions related to the GNSS antenna by leaving the zero antenna height. Usually, lever arm adjustment is made at the next step by photogrammetry software.
