surveybob
(Bob Harrrower)
December 25, 2015, 5:36pm
1
Initial REACH setup did not successfully finish and am unable to determine IP address of REACH unit. Neither reach.local or the default IP address work. Trying to reflash the unit to start again and using Windows Intel Phone Flash Tool Lite and it reaches 38% and stops with the following message
12/25/15 09:23:31.187 ERROR : [Port 0/1/5] Command "C:\Program Files\Intel\Phone Flash Tool Lite\dfu-util.exe" "--alt" "u-boot0" "-D" "G:\Reachimage\reach_image\u-boot-edison.bin" "-t" "4096" "-d" "8087:0a99"
failed
I have tried several possible solutions but so far nothing works.
Bob,
This seems to be not an issue any more since you have reported that you were able to flash it?
After reflashing the REACH unit several times and finally getting it to create a wifi hot spot I am unable to connect to it through Wndows on a laptop and through an ANDROID device the connection lasts about 30 seconds and then it goes through an ‘Authenticating’ process which it fails and the device returns to the home network. On a linux computer I am unable to access the unit by the default IP addresses. Many hours wasted on this and very little accomplished with getting the unit up and ru…
