hello i’am a new user of reach rs+ and i can’t found how i can have fix satut in base mode i get this message
Hi Adis,
To get a fix status on your base, it should get incoming corrections from any other base station. For example, you can connect it to an NTRIP station placed nearby. It’s needed to get absolute accuracy of the point.
You can also specify the base position manually if it’s placed on a known point.
Also, if relative accuracy is enough for your workflow, you can just average the base position in a single mode.
To learn more about the difference between absolute and relative positioning, take a read of this docs article.
