Hi Igor,
Thank you for improving the GPS quality for us.
I am sending my corrections from a Reach Base using TCP, to a 4G Wifi hotspot, that has a static IP.
I then receive the corrections on my Reach Rover using the same setup with a different 4G WiFi hotspot.
I have found that I have to set the GPS base as follows;
GPS set to 0.5Hz
BeiDou set to 0.1Hz
ARP station to 0.1Hz
With only these settings ON the Reach Base, I can obtain a FIX solution.
This takes awhile to achieve FIX and to be stable though. Once it does sort itself out, it is not too bad at maintaining a FIX solution.
If I up the frequency rates of these, it drifts in and out of FIX mode, but it is mostly in FLOAT mode only.
I need it to maintain FIX mode as I am using Reach to display to the user real time information.
My Questions
Now that you have added the AR and improved a problem with BeiDou AR. Would I get a better result if I enable AR mode on my Reach Rover in the RTK settings?
In the Rover, do I simply turn ON Glonass AR mode for this to work?
Is there something I need to do on the Base to enable AR mode as I can not see this setting?
Is there any other suggestions you could offer me that would improve the Base to Rover on the fly setup as used be myself, so as to help me maintain a FIX solution on the fly, as I have tried many things to do this without success?
Regards,
Cameron
