question -
When using the survey app I know whether there is a fix at the rover.
What happens if there is a reception or ambiguity problem at the base? . How will I know that at the Rover?
question -
I guess, you can look at your Rover’s ReachView (front-end) and see if there is a problem with the base, the Rover will not show a FIX on its Status page and if you look at the map on the Status page, you will see the location pointer jumping all over the place, if there is no good correction data coming from the base (over time)…
