Hi i8gnss
Is it possible to provide raw data (* .ubx) for this 20-minute session?
We are at the stage of developing a pre-processing progam in which the user will be able to remove signal interference. It will take some time but this test example can be useful.
Regards
Hi Ryszard
Here the raw data of the first measure and of the second. I’ve tried to measure with Swipos (Switzerland) and with Spin Gnss (of the near Italy).
Normally can I have real time position data or do I have to post processing to have the precision of 1 cm?
There are no disturbances in this session. For a precision of 1 cm, it is required to use VRS (NTRIP or postprocessed RTN). You can order such a VRS in SWIPOS. I checked only the quality of the measurement, which is OK.
On the evidence of two reports: Report_StaticIGS_i8gnss.pdf (176.1 KB) i8gn0030.pdf (104.5 KB)
My advice is to order VRS and calculate rtkpost. This should explain the reasons for failure.
Best regards
Ryszard
Hi
To finish this thread, I generated VRS_IGS (30 sec. interval). The conclusion is that only GPS satellites give correct results. It looks like there was operator interference during the session (a few times)
Best regards
Ryszard Report_RTN_IGS_i8gnss.pdf (499.0 KB) vrs10030.pdf (125.0 KB)
