Flowing the EMLID Navio2 DOCS step or processer, but it’s not operationg Navio2(Raspberry Pi 3) Drone!
Why?
We should share the information and technical support that it’s global time.
i’m using the flysky receiver(fs-ia6b), which is supporting ppm method receiver. my friend tell me, “you should use to ppm encoder.”, what’s the problem? finally, we should use to frsky or futaba receiver that is refered to EMLID Navio2 DOCS Manual?
Some of the receivers with PPM output:
For ACCST (most FrSky transmitters):
FrSky D4R-II 4ch 2.4Ghz ACCST Receiver
FrSKY V8R7-SP ACCST 7 Channel RX with composite PPM
FrSKY D8R-XP
For FASST (Futaba & some FrSky trasmitters):
FrSky TFR4 4ch 2.4Ghz Surface/Air Receiver FASST Compatible
How to confirm or find out the navio2 drone?
Of course, it will well start up and respose to your transmitter and cell phone.
But it’s no response and not operatiing, we should not operate and happen to problem originally.
First, owner’s navio2 drone, how to confirm and find out good and bad operation, which it is hardware and software?
Second,how to PWM, PPM, S BUS tx/rx setting?
Third, how to support android app which is tx/rx commuinicate? I know that it’s not refered how to ip server(ip router).
to frankly speaking, EMLID Navio2 DOCS, it’s ommitted in this point. we do not expert or …we may be beginer or …
EMLID Navio2 Raspberry PI Install and setting
Configuring Wi-Fi access
sudo nano /boot/wpa_supplicant.conf
sudo apt-get update && sudo apt-get dist-upgrade -
Installing ArduPilot
sudo apt-get update && sudo apt-get install apm-navio2
wget http://firmware.eu.ardupilot.org/Copter/stable/navio2-quad/arducopter-quad
chmod +x arducopter-quadsudo ArduCopter-quad -A udp:192.168.1.2:14550
sudo ./arducopter -A udp:192.168.1.2:14550sudo ArduCopter-quad -C /dev/ttyAMA0
sudo ArduCopter-quad -A udp:192.168.1.2:14550 -C /dev/ttyAMA0
sudo nano /etc/rc.local
sudo nohup ArduCopter-quad -A udp:192.168.1.2:14550 -C /dev/ttyAMA0 > /home/pi/startup_log &
3.Upgrade
Hardware configuration : OK
ESC Calibration : no response
Enable RC Failsafe! : no response
4.Video Streaming with Navio2
sudo raspi-config
sudo apt-get update
sudo apt-get install gstreamer1.0-tools gstreamer1.0-plugins-good gstreamer1.0-plugins-bad
ETC
sudo git clone --depth 1 GitHub - raspberrypi/tools /opt/tools
git clone GitHub - ArduPilot/ardupilot: ArduPlane, ArduCopter, ArduRover, ArduSub source
cd ardupilot
git submodule update --initgit clone GitHub - emlid/Navio2: C++ and Python sensor examples for developers
cd Navio2I followed this processor and step.
but why isn’t operate or startup?
what is problem and how to confirm to install and setting the navio2 drone?
I’m really wondering if?
(I’m using flysky tx/rx-it supprot to transmit ppm but it’s not to respose.previous, i try to binding and it’s normally operated. i guess to happen to problem that it’s originated from raspberry pi and rc receiver’s mixed to confess rc input and output.)
Hello there! Could you please tell what are you trying to achieve? Be more concise and patient, please!
The last post shows that you didn’t take into account what commands are to be performed on your PC and what are on a Raspberry Pi.
I can also suggest trying out our new beta as it’s easier to set up.
thanks a million, Mr.staroselskiy. i will ready to happen to me that it was proced the previous day, which it happened to me my raspberry pi and rc tx/rx
Latest WIFI
ip server setting(dhcp server)
Make the most adorable little WiFi router
emlid-raspbian-20170119.img vs emlid-raspbian-20161229.img
sudo nano /lib/systemd/system/ardupilot.service
sudo nano /etc/default/ardupilot
systemctl daemon-reload
systemctl enable ardupilot
systemctl disable ardupilot
Getting started with Emlid Navio+/Navio2
first, visiting the emlid webpage,
https://docs.emlid.com/navio2/Navio-APM/configuring-raspberry-pi/#writing-image-to-sd-card
https://docs.emlid.com/navio2/Navio-APM/installation-and-running/
https://docs.emlid.com/navio2/Navio-APM/ardupilot-upgrade/
https://docs.emlid.com/navio2/Navio-dev/navio-repository-cloning/
https://docs.emlid.com/navio2/Navio-dev/rc-input/
installing and setting, it’s ok.
i was used the rpi 2 b+, rpi 3 b, navio2 board, transmitter/receiver is fly sky fs-i6/fry sky x9d,
rebooting green blinking, later yellow blinking
no esc calibration, no response
but Navio2 example test, it’s ok.(GPS, LED, RCInput, RCIO, etc)
frankly speaking, it will be operated normally, (usingi mode2), but …
i wondering if what is followed navio2 board processer? not including gps.
What do i do the navio2 install and setting processor?
Autopilot installing and navioo2 example installing and testing!
I have a fly sky fs i6 transmitter and fs i6sb receiver (ppm supporting), and also fr sky x9d transmitter and d4r-2, x4b receiver.
Navio2 example test. Most of sucessful.
So i wondering if it require the basic procrssor that is tx and rx motors test, and how to set fly sky and fr sky tx/rx connecting and setting? More detail and specific picture and moving picture?
Could you tell me how to set up the fly sky fs i6 transmitter and fs i6sb receiver (ppm supporting) for the sucessful navio2 drone?
Could you tell me how to set up the fr sky transmitter(x9d) and d4r-2 receiver for the sucessful navio2 drone?How to confirm to basic install and normal check out?
Could you tell me how to set up the navio2 for the sucessful quadcopter?
