Hi, there. I have installed the upgrade from version 2.8 to 2.9 and now my Emlid Reach M2 does not work anymore. When I connect it to the power supply and the baterry, only amber light no other lights are lit. I can also recognize the reach:F6:9D on my wifi connections and I can connect to it, however when I try to connect Emilid app it simply does not work anymore.
As in the computer can’t see the Reach Hotspot? Or you can’t see it when it is connected to the same network as your computer/device? I did do a factory reset once I got 28.4 back on… Make sure to screen shot any important settings.
Thanks Michael again! You are a legend! I did actually manage to flash my M2 back to 28.4 version. It did not work at first because I used a charging cable not the data cable! Silly me. Yes, and the device is now working just fine with the 28.4 version. DO NOT INSTALL 29 Beta as yet!
Thanks for letting us know about the issue you encountered! Can you please share the serial number of your device with me? You can find it at the bottom of the unit, under the bar code.
I just want to mention that if the unit lights up the red LED only, it usually means there is not enough power for it. So it’s better to check the cables and the power supplies first. If the issues persist, contact us at support@emlid.com.
Our 29 beta 1 is indeed a beta version that you can update for new features. It can contain some bugs that’s why it’s better to avoid using it for important fieldwork.
Hi, Polina. Thanks for the response. I have resolved the issue by retracting back to v 28.4 and the device is now working just fine.
I tried at least three different power supplies with it and it did not change. Then I just reflushed it with the v 28.4 and it all comes good. Yes, I agree the v 29 beta 1 I did install on my own risk so yes, it was my fault.
@zorzterzic, glad that everything’s working for you now! Just to check out what may cause issues on the latest beta, we need to analyze any error data. That’s why I thought that maybe we will have something in our system from your unit to check out.
