Firmware Emlid Rs2 V 28.4 .zip
I have a problem with my RS2, I have an intermittent problem in RTK and NTRIP receiver mode (in mode base is working fine).
I have another 2 RS2 working fine, the only difference is that the equipment with problem have firmware V32.2 and the others 2 have firmware 28.4 and they working fine, so I need to test with V28.4.
I hope your help.
Best regards.
Here’s the link to the Firmware Reflash Tool. Follow the instructions and you can put a previous version back on.
Hi Michael, thanks for your response. I used the Reflash Tool, but that software requires the firmware in .zip format, which I couldn’t find. However, I installed the V33 firmware using Emlid Flow and conecting to a external wifi, and that solved my problem. I hope this information will be helpful to anyone. Best regards for Emlid Community
@etorresmoya,
We don’t support firmware downgrades, as the latest version includes critical fixes and updates to ensure optimal performance. Using outdated firmware could limit our ability to assist with future issues, and we want to ensure you have the best experience possible.
I am glad that updating the firmware version solved the issue.
Edit:
Updated my answer
