Is there any way i can find out the settings for the correction input and output from an old survey or via the logging?
I am wanting to check to see if the settings have changed because i cannot connect to the base.
cheers
Alex
cheers
Alex
There is some header information that you can read a the beginning of the .POS file, but I don’t think you will find what you are looking for. If you have the RINEX files, you could analyze the log files in RTKPLOT and look at satellite systems enabled, and zoom in to see the frequency or sample rate. That also goes for any saved RTCM3 file which can be converted to RINEX and analyzed in by looking at the text and also in RTKPLOT.
I think that’s about all you can do unless you took notes.
