Hi Emlid,
A feature request for you for Emlid Studio…
Could you add in a report file to be produced whenever ES performs a processing run. Having the processing report would help keep track of settings and files used, and would also provide a useful record of information to be added to client reports.
I’d envisage the report to be a simple plain text file containing something like:
- Software Name & Version eg Emlid Studio 1.8
- Date & Time of processing run (start/end)
- Type of Processing Run eg Static / Drone / Stop & Go etc
- Names of the Input Files eg the .rnx, .24O, 24P, .mrk, .nav, .obs, .csv files
- Position Details for Base - eg RINEX Header, Lat/Long/Height dd/dms, XYZ, ECEF etc the position data used
- Names of the Output Files - eg .csv, .pos etc
- Processing parameters used - ie Emlid Studio Settings for Filter type, SNR, integer Ambiguity etc.
Sometimes multiple processing runs are performed when trying to get the best results for a set of observations or a point fix, and it’s not always easy to keep track of which settings you used for which set of results!
Maybe something like:
> Date of Processing 11 April 2024
> Start time
> End time
> Processing Parameters
> Base Location Lat/Long/Height dd
> ETRF89 RMS
> Lat 55.64721762 0.011
> Long -2.77042009 0.005
> Ellip.Height: 264.595 0.02
> Solution FIX
> PDOP 1.1
> Antenna Height 1.934m
> Averaging Start 2024-04-11 14:36:46.2 UTC+01:00
> Averaging End 2024-04-11 14:38:46.2 UTC+01:00
> EMlid Studio 1.8
> Processing Drone Data
> Use Base Observations On
> Filter Type Combined
> Elevation Mask 20 deg
> SNR Mask L1 l2
> 35 40
> Satellites GPS SBAS GLONASS GALILEO
> QZSS BeiDou
> Integer Ambiguity GPS GLONASS BDS
> Resolution FIX & Hold Fix & Hold On
> Input Files
> Drone Observation File Droneflight_PPKOBS.obs
> Base Observation File RS3_raw_20240411090309.24O
> Drone Navigation File Droneflight_PPKNAV.nav
> Drone .MRK File Droneflight_Timestamp.MRK
> Output Files
> Droneflight_PPKNAV_PPKOBS_events.pos
> Droneflight_PPKNAV_PPKOBS.pos
> Original images updated No
> Images processed 200
> Image output Directory directory\name\here
I appreciate some of the information is already present in the processed output files, but it would be useful to have it collated into a single file.
