It would be great if we can preset a suffix name (In ReachView) to downloads file name (Ex. ROVER_xxxxxxx.UBX or BASE_xxxxxx.UBX ) to make the processing organisation easier.
Noted, thanks for the submission.
I also think that could be nice - but is the current behaviour not due to the fact that a Reach RS set up as a base can also simultaneously work as a rover?
When you look at the status of the base unit it lists number of satellites but as “ROV: X” not “BAS: Y”:
Cheers,
Lars
Every device is identical and can act as a rover, as a base or as both simultaneously. They don’t have a “role”, they simply have a correction output setting.
