Hello Sveltana
Here is a whole log :
solution_202008210727.XYZ.zip (24.6 KB)
But I don’t think you will find anything interesting, there isn’t any antenna information.
Usually, phase offset center values are just in several millimeters, so it doesn’t affect the accuracy a lot, and it stays within the normal range.
It was true for Emlid single frequency receiver, but the M2 is far more accurate and you can except an height error lower than offset antenna (some have up to 14 cm offsets).
I did a post processing with the M2 on a benchmark, with antenna offstet taken into account, and I have a Z accuracy of 2 cm.
