Hi guys,
I’m actually making my very first drone with the Navio2 flight controller, and I’d like to use the new “Fatshark Scout” FPV glasses in my setup.
Unfortunately, I cannot retrieve any information about this… Someone has any links of information to share on how to connect a Fatshark to a Navio2?
Could it work with the standard Raspberry camera, or do I need separate hardware for this?
Thanks a lot!
Hi @challenge796,
If the transmitter you’re using to connect to the glasses has a UART port, it should be possible to integrate your hardware with the Navio2.
However, we haven’t tested this setup so I can’t suggest anything more specific. Let’s see if our users can help you with that.
system
(system)
Closed
5
