I’m trying to run PX4 on navio2 and I’m getting this text output as well as the servos trying to over extend and making a horrible noise. The servo failure noise happens directly after ekf2 start in the .config file. Here is the output:
commands file: ./posix-configs/rpi/px4_fw.config
| ___ \ \ \ / / / |
| |/ / \ V / / /| |
| __/ / \ / /| |
| | / /^\ \ ___ |
_| / / |_/
px4 starting.
INFO [dataman] Unkown restart, data manager file ‘rootfs/fs/microsd/dataman’ size is 11797680 bytes
ERROR [drivers__linux_gpio] read 4: open: No such file or directory (2)
ERROR [drivers__linux_gpio] export failed: write: Device or resource busy (16)
ERROR [navio_rgbled] red led: failed to export
ERROR [drivers__linux_gpio] unexport 4: write: Invalid argument (22)
ERROR [drivers__linux_gpio] unexport 27: write: Invalid argument (22)
ERROR [drivers__linux_gpio] unexport 6: write: Invalid argument (22)
Command ‘navio_rgbled’ failed, returned -1
WARN [commander] Buzzer: px4_open fail
WARN [commander] Buzzer init failed
WARN [commander] Preflight checks always pass on RPI.
INFO [mavlink] mode: Normal, data rate: 1000000 B/s on udp port 14556 remote port 14550
Sleeping for 1 s; (1000000 us).
INFO [logger] logger started (mode=all)
pxh> INFO [mavlink] using network interface eth0, IP: 10.0.18.10
INFO [mavlink] with broadcast IP: 10.0.18.255
INFO [navio_sysfs_pwm_out] Loaded mixer from file ROMFS/px4fmu_common/mixers/AERT.main.mix
INFO [lib__ecl] EKF aligned, (pressure height, IMU buf: 17, OBS buf: 16)
Exiting…
ÿShutting down
Restoring terminal
