We have purchased 2 new RS2 units and 2 New M2 Units. With a bit of a struggle I have got a result from the RTK Lib Software.
I am faced with one problem though, I have 170 Images and 174 events. The problem is none of the events have odd times so cannot Identify which 4 events must be deleted.
I have deleted the first 4 and get an error in pix 4 d, I have deleted the last four and get an error in pix4d aswell.
May I ask you to share your raw data and events files with us? We can check the time spans between them and find out the time marks that should be removed.
Thanks for the tip. There are alot of 00:00:00 times when deducting them from each other. When I delete these there are identical number of images to Events.
I’ve looked into your data and these are the results.
You can see the initial and the improved PPK results on the plots below. The initial solution had 41.9% of fix, the improved consists of 85.3 % of fix. Also, you can find the settings I’ve used: Combined Filter Type, Elevation Mask = 20, and standard SNR Mask.
I’d like to point out that the quality of the satellite signals observed by the rover could be improved. You can see a lot of cycle slips on the plot. Rover tracks only 3 satellites with SNR=45. This factor causes difficulties with obtaining fix solution.
May I ask you to share the photos of the hardware setup? They will help me to understand what can be improved for better performance.
It’d be nice if you have a chance to share the log as it helps us a lot in preparing the fix for the issue. The more data we have, the more tests we can do.
Also, would you mind sharing your hardware setup photos? It’s essential for us to see how you connected the M2 unit to a camera.
We’ve just updated the RTKLIB version in our docs. You can now convert all your UBX logs using a new version and get the files with the correct time marks quantity.
