I would like to use an external antenna to log raw GPS data. I mounted a Tallysman 3742 on the Solo but I think the mount and ground plane cause some shadowing on the internal GPS. I found a DF13 -> molex click mate cable (https://store.mrobotics.io/6-Pins-CLIK-Mate-to-6-Pins-DF13-Connector-p/mrc0207.htm ) and am curious if I can use the cable to bypass the onboard GPS. If I am not interested in implementing the RTK do I have to make any changes to the Reach message stream or Solo firmware?
Alternatively is the a way to bypass the patch antenna on the Reach Solo card?
Thanks
Jim
