Hello all
Can you use the position 1 or 2 ports on a Reach RS2 to send the rtcm3 correction signal over the rs232 serial port to an external radio ?.
Using TX and RX pin 6 and 7, on the 9 pin plug on the bottom of the Reach RS2
Thanks in advance
Hello all
Thanks in advance
Yes if you set it up in the App for output corrections serial.
Hi Jonny,
Yes, you can do that. Do not forget to select the corrections output on RS2 via Serial in ReachView 3.
You’ll need to establish the GND connection as well.
