Exporting to dxf
Hello
I have a a question that has been bugging me for a while.
when I export my collected points in RX and export them to DXF , then DWG. I am able to see the point number, code and the elevation. My question is where is the actual location of this point? see snippet below?
thanks for any feedback
You might want to try the command in AutoCAD “pdmode” . This sets the style of the actual point like a point, circle, cross etc. There’s other like “pdsize” etc. Look in the help command.
Agree with @EBE111057
Did that white linework also come through that may be connected to each point? Can you snap to the end points of the linework? Or window select around that area you think point is to select the actual point? Or select them via the layers?
Youtube has many tutorials on how to handle points.
f86e4f43199164d128bf84ee38096fc993d3adff
Just review the properties of the point and you’ll see your xyz grid coordinates. You can label the cords but why?
Thank you for you feedback, I was able to figure it out
