Is it possible to export survey points as a text file in PXYZD or other formats?
I see you can output as a SHP or DXF file and that could be a workaround.
I need to get the data into excel so I can convert to feet, generate orthometric elevations etc and then import it as a text file to other software.
If not - a data export function would be great.
Most GIS/Mapping software can read an XYZ or PXYZD text file.
Cheers
John
